b18a1 into Del sol
Discussion in 'HYBRID -> EG-EK / DC' started by honsol, May 6, 2012.
  1. honsol
    honsol New Member
    Im doing a ls swap into a 95 delsol and I was told it would bolt up but the motor mounts are different and the wiring is also different need help
  2. iluvemyegg
    iluvemyegg New Member
    corpus christi tx.
    nothing swaps right over trust me i went from a b16 eg to a b20 eg, do your research
  3. serrilion
    serrilion In my own little world! VIP
    Vermont
    You were correct. You r going to need Integra Motor mounts from I beleive 97+ mainly the upper trans mount, upper drivers mount and the Rear T mount in the back. Wiring should be strait forward depending on if ya Sol was Vtec or Non Vtec. Only thing your really going to need is a Trottle cable from a B Series, as the D is a bit to long or short I can't remeber and doesn't bolt to the intake manifold then u get throttle issues.
    Other than that the motor should drop right in, mounts from the integra, as well as axles, p75 ECU, and check on ya Shift Linkage as the B series mite be to long and u mite need to 1/2 and 1/2 the integra and del sol stock linkage. Best of luck!:D
    Do your research? Your and Idiot. Del Sol's came mostly with a Stock 1.5L (d15B1) non Vtec motor, or a D16z6 (SOHC) vtec motor... its rare to find the Del Sol with a B series swap into it, which in that case he would still need some mounts at the very least
