b18a1 map sensor and vacumm diagrams needed
Discussion in 'ECU's, Electronics, and Tuning' started by mattyoung2002, Jul 28, 2011.
  1. mattyoung2002
    mattyoung2002 New Member
    i got my b18a1 swap under way in my 90 civic hatch everythings going good until i got looking at my map sensor plugs and they are differant. im guessing that im not able to use the civic map sensor since it has less outlets on it. do i just splice on the DA plugs and use the DA map sensor unit??? any help would be appreicated so im able to go on to the next step
    this is what i got
    90 civic si hatch (clean no rust)
    b18a1 low mile jdm engine n lsd trans
    stage 3 6 puck clutch
    light flywheel
    hasport mounts
    hasport shift linkage
    aem cam gears
    dnx 421 header
    3" dnx polished ss from engine to muffler
    mishomoto red hose kit
    tein springs
    megan rear lower control arms
    megan rear camber adj.
    polished alum radiator
    ima b tryin to put sum pics up real soon any help would be great this civic needs to get back on the road:mellow:
