b18a1 parts
b18civic1013
does anyone know where to buy good quality parts for a b18, not abey either: things like bearings, pistons, and stuff like that i know where to get cams and stuff but can't find some parts i want
you can use honda bearings but those are a bit expensive (700.00) I haven't had any experience with clevite bearings but I have heard they make a good product. what kind of pistons are you looking for forged? or just replacements?
when I was doing my rebuild I called acura of fife and the guy in parts told me something like 720.00 for main and rod bearings alone, and I almost shit my pants.
clevite makes good bearings. SURF THE NET you might find something cheaper. As far as piston it all depends on the compression you want i used to have b16 pr3's in my ls block
Quoted post[/post]]
Rod 11.92 * 8 = $95.36
Crank 12.34 * 10 = $123.4
no where close to $700, the guy in parts mustve been an idiot.
Quoted post[/post]]
Quoted post[/post]]
Honda and Acura parts counter guys I have run into have almost always been total highschool dropouts.
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
exactly...
how much do you want to spend? If you want to redo the ENTIRE bottom end, just buy an entire kit. I found one on ebay for 1200. your choice of compression. I chose 11.3.1. All eagle. hbeam rods,lightweight eagle crank,srp piston,rings,etc. oohhh and its all balanced. the only thing i had to buy seperate was the clevite bearings.
that was my choice. Figured i'd give you something to think about
