B18a1 running way to rich
Discussion in 'Civic and CRX - EF' started by Efjunkie125, Sep 8, 2016.
  1. Efjunkie125
    Efjunkie125 New Member
    Have a b18a1 swap in my 91 dx. I did the swap myself and everything went fine except for the fact that I get absolutely horrible gas mileage. I did have someone help me with vacuum setup and I realized yesterday the vacuum hose going to the map was unplugged, I plug it up and my car idles around 2500 rpm. I unplug it and it idled fine. Is this why I'm running rich? Or something else entirely
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Lots of factors here, go over wiring , pull CEL codes ( light blinking on ecu ) go from there
  3. Solomon93
    Solomon93 Member
    ALSO be sure you didn't cross the two distributor wires, they can severly retard the timing and you will *think* its running rich when really the timing is too far off to have a complete burn. Food for thought.
