b18a1 swap crx hf wiring
camaro boy
not shure what to do? engine harness does not match car harness what to do?
Quoted post[/post]]
Quoted post[/post]]
You've gotta use your stock harness, and convert your car to MPFI. There's a great writeup here: http://www.gutterslide.com/fourthgenhatch_mirror/mpfi.html
:thumbsup:
his car is HF which is MPFI - but, yes you need to use the HF engine harness - it should plug into everything - you will have a connector leftover which went to the HF EGR valve
Dammit...I knew that...lol
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
:thumbsup:
i knew you did - thought you just didn't see HF in the title
Every time I see HF, I think 'Civic STD small-splined axles', and I automatically think 'DPFI' beacuse of the relation to the STD...
:shrug2:
