Wanting some knowledge on how this B18a1 swap will work with the Map sensor. Do I use the LS MAP? Or the A6 MAP? Or do I have to manipulate the system? I searched this topic but found dead ends?
just use the MAP that is already on the firewall, unless your engine has the MAP on top of the throttle body - if so, use it - just extend the wires on the MAP connector so that it will reach the throttle body and plug it in
