I Successfully swapped my B18a1 into my CRX last night. Took my and a buddy about 6 hours to pull from my integra, install new parts, and reinstall into my CRX. Went smothly concidering they are both midwest cars. The gas axe was much help. It also helps when you have side by side hoists. Anyhow with one push of the button he popped right off and ran smoothly. No check engine lights and drives perfectly. Well I need to align it still. A little squirrely at the wheel . Then i will clean up the engine bay and dress it up. The only issue was the vacume routing. I could find nothing on this topic. I ran the vacume with what I believe to be right. Ill post pictures later on another topic of the routing. Anyhow Thanks for the help and info handa swap friends.
http://carphotos.cardomain.com/ride_images/4/208/1901/38018450041_medium.jpg
