b18a1 swap
Discussion in 'General Tech and Maintenance' started by elcangripapiex, Sep 12, 2004.
  1. elcangripapiex
    elcangripapiex Member
    Just lookin for a exact list of what is needed for a successful b18a1 swap
    Thanks
  2. hybridalien
    hybridalien Member
    what car????
    assuming it's a ef (basic stuff)
    all LS (B18A1) parts
    motor mount
    shift linkage
    ecu
    motor
    tranny
    axle
    i don't think i miss anything
  3. elcangripapiex
  4. hybridalien
    hybridalien Member
    do a b18b,why? Because you can reuse youre stock wiring harness(obd1 b18b)
    on b18a thats means : obd1 to obdo conversion(not legal)
    or rewire all the sensors to fit the obd1 harness right in the car.
  5. elcangripapiex
    I heard bout that to late, I already own the b18a1 and upgrades for it so theres really no turning back now :doh:
  6. hybridalien
    hybridalien Member
    try to run a 94-95 ecu or rewire i think these are the two most easy ways
  7. driverunknown
    driverunknown Senior Member
  8. 92civicb18b1
    92civicb18b1 The Trisexual
    sell it to me for cheap, i don't want the trans though. what year is it?
  9. elcangripapiex
    either 92 or 93 b18a1 without trany,ECU,wire har.
  10. driverunknown
    Seel it all separately and make your money back. Then buy an obd1 with a hydraulic clutch.
  11. hybridalien
    hybridalien Member
    he's right less troubles
  12. 92civicb18b1
    Yea, sell the complete longblock motor to me for 400 shipped (had to throw out an offer). Seriously, email me if your gonna sell it with a price. bhj0887@yahoo.com. I don't mind the extra work.
    But to be honest with you if it's a 92-93 your good, its already obd1 and all you'd need is a hydro trans.
  13. brian11to1
    brian11to1 Senior Member
    92-93 B18A is OBD1 and you can use teh stock engine harness on the OBD1 LS motor.
  14. hybridalien
    hybridalien Member
    I tought 90-91=b18a
    92-01=b18b
    my error
    In fact 90-93=b18a(92-92=obd1)
    94+= b18b(96-01=obd2)
  15. bulletproofhoodies
    bulletproofhoodies Member
    LAKE WORTH , FLORIDA
    WHAT ABOUT A LS IN A 90 CIVIC HB
  16. CRseX84
    CRseX84 Senior Member
    SUNY Canton College, NY.
    if the b18 is a from 90-91 it is obd 0 and no conversion is needed to go in the ef... except hardware... (mounts, linkage, axels, etc), i dont see why u cant use the obd0 b18a in the eg.. i have a eg, i got a full 90 b18a for 100$ im rebuildin it in class in college, and all im doin to swap it in is use new injectors, and a obd 1 distributor and eather a p75 or a p74... and what ever plug connections need to be converted i will use part of the obd 0 harness.... whats the big dea?? iv talked to alota ppl bout it and said thats all i g2 do for it to work...
