b18a1 swap
Discussion in 'Civic and CRX - EF' started by celicaboy1984, Oct 5, 2007.
  1. celicaboy1984
    celicaboy1984 New Member
    just wanted some info on a few things im swaping a b18a1 into my 90 civic si ..I noo i can use my wiring harness and use b18 computer obd0 and i got the hasport mounts and shift linkage taken care of...but was wondering about the map sensor do i use the one out of the integra? and the same with the alternator? what one do i use.. thanks for any help :)
  2. drummingpariah
    drummingpariah Author of the Madness Man
    Bay Area, CA
    The Integra alternator is attached to the motor, not the car. Use that alternator. If you're using your si wiring harness, you'll want to stick to the si map sensor. It's not ideal, but it'll work and it's plug-and-play.
  3. celicaboy1984
    thanx i no the alternators attached to the motor i build motors but new a t honda swaps...i used the b18 map sensor and it works good stioll pluged in...any reason you say to use the si one? i heard i will run lean if you do cuz its got less flow ratefrom the injectors
  4. drummingpariah
    Bay Area, CA
    I suppose that depends on the injectors. I went with the pm6 because the ecu is worlds more tunable, and the map sensor is simpler. The pr4 is picky about what you can change, pgmfi-wise.
  5. drummingpariah
    Bay Area, CA
    Any update on your project? Good/bad/ugly/pretty?
  6. AaronH
    AaronH New Member
    Hey I just helped my buddy put a b18a1 in his 90 crx, everything went good but we are throwing a code 13 and I cant find any info on how to fix it, can you help me
  7. Briansol
    This thread is from 2008.... probably not going to get much out of the OP.
    What ecu are you using?
    What obd did you end up at?
  8. jlicrx
    jlicrx Senior Member
    Colorado Springs
    is the car
    the barometric pressure sensor is in the ECU for the B18A1 engines - try a different ECU
    could also be a problem with the wiring and the code 13 is just a result of the ECU trying to find a possible solution - may not be the problem at all
