i have a b18a1 i'm putting in my 93 civichatch cx that i would some time in the future like to make into ls/vtec. I have the cable tranny for the motor but was thinking of selling it for a hydro. Is that a good move? If so, are b16 or b18 trannys better per $?
as far as the hydro vs cable portion it kinda comes down to preferance
as far as the actual trannys there are much better trannys available in hydro form
I can't confirm it, but I have been told that the hydro tranny synchros are stronger, but I do not know for sure. As E_Sol_Si, your selection of trannys is much better with cable.
r b16 or b18 trannys generaly better or does it matter by the exact model. I was looking at b18 ls tranny's or maybe a b16 which whould be better to put on a b18a1.
If you are running NA this is the order of trannys I would look for (from best to worst)
JDM Type R(Teg or Civic)
USDM Type R
GSR (USDM or JDM), Del Sol VTEC, 99-00 Civic Si (or any hydro B16 tranny except the CTR)
LS (This tranny suck royally for NA)
teh b16 or delsol tranny's have a smaller differential than it's 1.8 counterparts. I agree with lsvtec with the order of trannys except I would put the GSR after the SiR gearing
