B18B Block Questions
Discussion in 'Forced Induction' started by xxji3lazexx, Feb 14, 2011.
  1. xxji3lazexx
    xxji3lazexx 1SIKEK4
    RHODE ISLAND
    what do i have to do to my block so that the engine will handle me boosting it on 7lbs and having it LAST.please someone
    its going to be daily driven and i just want enough horse to shit on all n/a cars around me,im goin to buy a ebay turbo kit but gong to switch the turbo afta i discover lag issues to a gt30 greddyand use a hks BOV.Do i have to change my radiator to a racing one.there really isnt a budget because there no time limit,the ls runs fine no leaks motor only has about 80k,can someone please help me out here.
  2. xxji3lazexx
    xxji3lazexx 1SIKEK4
    RHODE ISLAND
    more question:if i get forged rods can it still go together with my b18b1 pistons so i can keep my compression still low but maken my block heavy duty.
  3. Matts96HB
    Matts96HB . Moderator VIP
  4. Egturbohatch
    Egturbohatch New Member
    from wat u sayin, da motor is healthy...nd wit 80k miles on da motor is low so if u was to run boost on only 7lbs it would handle lovely, as long as you TUNE it. wit everything stokk nd in good running condition a Ls motor can handle up to 300hp wit good tuning so u pretty much on da right trakk, just keep researching nd ull be good.....good lukk!
  5. xxji3lazexx
    xxji3lazexx 1SIKEK4
    RHODE ISLAND
    im ganna run hondata with boost option, and changed my mind on ebay turbos im going percision gt30r.dsm black top450's,for a nice spool im using a ram manifold and when i get it tuned its ganna cost me 450 just for a street tune so it should be a great tune correct
  6. hondafreak513
    hondafreak513 New Member
    O hi O
    I was about to say the cheap ebay turbo manifolds break easy.
  7. xxji3lazexx
    xxji3lazexx 1SIKEK4
    RHODE ISLAND
    should i rip the head off and throw arp head studs and head gasket
    or is she still healthy
  8. Matts96HB
    what the fuck is going on in this thread!? so much shit I can barely decipher, and so much misinformation!
    300hp on a BONE STOCK LS? with 80k (and judging from the nature of this post, they were HARD)miles on the clock? :no:
    I wouldnt trust the weak-ass rods in a stock LS past 225whp on an IMMACULATE tune. even then, id still feel like my time was limited with a running engine.
    also, 7lbs generally doesnt tell us anything.. 7lbs on a small turbo is far different from 7lbs on a large turbo.
    450 is outrageous for a street tune. i paid $100 to have my car street tuned twice on CROME, and then dyno tuned. you are getting worked.
    also, high price doesnt mean itll be a good tune.
    fuck hondata. get a chipped ECU, and fine someone that knows what they are doing with CROME or another free program.
    your build is missing one thing: internals. youre planning on running a gt30r on a stock LS. that just doesnt make sense to me. a 450whp capable turbo on a 225whp capable engine. fail.
    get some decent pistons and rods, rebuild the engine, and do it right the first time. larger injectors, and a fuel pump, hello worth-while build.
    they do,and re-welding them just worsens the problem. get a quality ramhorn.
    you can re-use the ARP head studs, unlike OEM bolts.
    id tear the engine apart, rebuild with nice pistons and rods, and go from there. thats just my .02, coming from someone who has done this EXACT SAME THING BEFORE.
