b18b crx swap 1320 times!!
Discussion in 'HYBRID -> ED-EF / DA' started by rextec, Sep 16, 2003.
Thread Status:
Not open for further replies.
  1. rextec
    rextec Member
    i swaped an obd2 b18b into my 88 crx dx and the best quarter mile time i can muster on the gtec is a pathetic 15.9 at 90.1 mph. my car has a test pipe, tanabe 2 1/4in catback exhaust, and aem cai. full interior, no ac/heater crap under the dash. is this a normal time? is my gtec inacurate? does the trap speed indicate a bad launch? anyone else have times for a similar setup?
    thanks
  2. b164gen
    b164gen Member
    whats your trap speed and a b18 you should run low 15's at the worse
  3. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    90mph should be high 14's. but gtec is crap, take it to the track if u want a real time. also, when u go to the track, check your 60', if u cant get 2.2's then u need to work on it. a b18b should be able to get high 14's stock. also gut ur car.
  4. rextec
    rextec Member
    anyone else with similar setup and your times?
  5. jspecivicsi
    jspecivicsi Member
    the only way a b18b will run a high 14 is to tare down the internals and throw Pr3 pistons on your stock LS rods, header,Fuel rail,and skinnier head gasket so until then low 15s are good for that motor
  6. crx
    crx Senior Member
    cali near sac
    my friend ran a 14.3 with a act 6puck,cutoff.
    -joseph
  7. civichbwithb18a1
    civichbwithb18a1 Member
    i got a 14.00 flat with b18a1 gutted no ac or heater header ram air intake wires and underdrive pulley. but i also had a b16 tranny. 1.7 in the 60
  8. mellowboy
    mellowboy Senior Member
    ChicagoLand, ILLINOIS
    THen what happen to your thermostat? ;)
  9. honda boy hlt
    honda boy hlt New Member
    hudson lake
    you bypass the heater core and leave the thermostat in
  10. Jeef
    Jeef NO MA'AM Moderator VIP
    This thread is 5 years old. Please do not respond to old threads.
Thread Status:
