stranger_danger
i have just come into possesion of a 96 eg hatch and it has a b18c gsr the risd pin came out scarring the hell out of the cylinder walls so the block is garbage but the rest of the motor is good ive been looking for the b18 block whole rotating assembly my freinds going to sell me his b18b and im going to use the block from it after its bored and replained but what i need to know is if the valves are going to clear the piston when i hit vtec because the gsr has dished pistons im going to do a clay test but i want to know before i have it all apart also is a gsr wiring harness obd2 going to run it bolt in and is there any other problems i might run into i should no about im going for motor out motor in i need a quick fix any one in calgary alberta with a b18 block rotating assembly for sale
