B18b Head Milling?
Discussion in 'Engine Building' started by Ractive78, Jan 27, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    I was wondering how far I should get my B18b head milled, for higher compression? What kind of Hp gains could I expect? Decided not to go with valve job, saving money for gsr head.
    Thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    None, just get some high compression pistons. Milling the head dicks with valve/piston clearance too much. Do it the right way.
    <whore>On that topic I have a set of LS rods with B16 pistons (yeilds around 11.4:1with LS head) on them that I will let go pretty cheap, PM me if you are interested.</whore>
