B18b Head On B18a Block?
Discussion in 'HYBRID -> EG-EK / DC' started by Ractive78, Jan 15, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    Im looking for a b18b head on my b18a block. I was wondering if it would drop on without any mods. Can I use my ecu from the b18a its a obd0. I heard that the b18b head is a lot better that the b18a head, and the blocks were basically the same. Is this true? I was planning out getting the head milled how far can I safely do that with an b18a block and stock pistons? If I get my head milled how far do I advance the Cams?
    Should I get a hydro trans for it, if so where could i get one?
    Thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Only post in one forum.
  3. Ractive78
    Virginia, USA
  4. pissedoffsol
    IMO, the gain isn't worth the hassel. you are talking 5 hp probably...
    and milling heads are bad, at least to me it is..
