b18b in 5th gen cx
typesiracing
okay...bottom line....which mounts from the civic can i keep and which do i need to replace....this is my first experience with a b series so i'm not as familiar. i have the rear mount off of the teg but the two side mounts and the little front small mounts are destroyed so can i use the originals from the civic. any help is appreciated.
Merry Christmas.
What it boils down to is, all the mounts are the same except the torque mounts, which are the two in front that bolt up to the underside of the chassis on either side of the motor. You need to use your civics rubber mounts and the brackets that bolt to the motor.
