we are not here to "send you all the info we can" its your job to find all the info you need...
start by going to hasport.com and checking out their mount kit for b series into the first gen crx...
then read their instructions...
then order motor, mount kit, linkage, axles, wiring etc etc etc from them...
http://hasport.com/Tech/Installs/AFB1.htm
boo ya, can you habdle all this work?
B18B = hydro trans
you should really look into getting a B18A swap with cable trans and preferably OBD0 if you can...
