B18B in 92 CX wiring ?
dansace
Member
I have finally decided on my swap and am going to get a USDM b18b. I found a great price on a complete swap and have a few questions. Can I use the teg harness in my civic? Does it just plug in? Do I need to wire anything else since it doesn't have V-Tec (knock sensor or anything else?). Will the axles work with my hubs? Thanks for the info! Also will my stock throttle cable work with the b18?
the axles will work with your hubs
if you can just try to get the LS harness with the swap
if not then you will have to convert to a 4 wire O2 sensor and lengthen a few wires (if its OBD-2 there will be a little more)
you will need the LS throttle cable
yup just use the LS harness everything should plug right in .... you are going to have some exhaust issues
your cat is on the "header" the LS is between the header and exhaust
gunna need to do some fucking around with it to get everything to work right
yes it will be right about at the firewall
if i remember correctly the CX has the cat up in front of the engine doesnt it???
your right but I did away with that along time ago.... I think i will bolt up though...just need to put in a cat.
