B18B into a 95 hatch CX
Discussion in 'HYBRID -> EG-EK / DC' started by 95hatchcx, Dec 31, 2003.
  1. 95hatchcx
    95hatchcx Member
    I have a 1995 honda Civic Hatch Cx, i want to put a B18B ls motor in my
    car. The first question is can i use any B18B from any 94 and up integra? are they
    all OBD1 motors? The second question is will my factory ecu from the 95 CX work
    with the B18B? and will the motor mounts from the stock motor work or will i
    have to use integra motor mounts? List everthing i will need to make this work, my my concern is to i have to have certain year for the integra motor to work or will any motor from 94 and up work?
  2. E_SolSi
    all OBD1 motors?
    94 - 95 will be OBD-1
    96+ will be OBD-2
    with the B18B?
    no... get an OBD-1 LS ECU
    use the integra mounts
    search .... this has been covered many times
    if you get a 94+ USDM B18B complete with the harness, tranny, axles, mounts, throttle cable, and an OBD-1 LS ECU it will all swap right in with little to no headaches
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The CX ECU will "run" the LS motor, just like shit :(
