b18b into a del sol
Discussion in 'Civic and del Sol - EG and EK' started by xcthc, May 30, 2008.
  1. xcthc
    xcthc New Member
    i know i'll need 94-01 integra motor mounts... but what would i use for the all the tranny brackets? do they have to be for an LS or a del sol VTEC? or can i just use the ones from the original d16 trans... thanks. i did search and the answers i found were vague.
  2. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    hey guess what.........search.........d series mounts WILL NOT WORK. ls and del sol VTEC are the same thing. find a del sol VTEC in a junkyard and strip the mounts from it....those workwork
  3. xcthc
    xcthc New Member
    first, i wasn't talking about using d-series mounts. i was talking about using d-series brackets.
    i know ls and del sol vtec would be the same thing in terms of what series the motor is.. but then again, i can't use ls shift linkage, which is why i'm asking.
    find a del sol VTEC in a junkyard? oh sure thing... the junkyards near me are just full of them....
    thanks for the free bump
  4. BrutalB83
    Rochester Hills, MI
    Have you checked E-Bay? I've seen Del Sol VTEC shift linkages on there occasionally...
