B18B into an EF
SpoolFedEF
Im looking for info about how to complet this swap (ill be buying the enigne soon) and i want to learn how to put it in... i dont see any articles about the B18b, they are all about B16's... why?
because the b16 came in ef's in japan and is the most common ur going to have to convert odb which for some people isnt very fun with the wiring an mix and match of certain parts !~
[post=405690]Quoted post[/post]​
Do you know what you are talking about?
You dont have to convert OBD's... you can run the engine OBD0, by using 90-91 Integra (PR4) ECU, Distributor (TC07A, TD23U, & TD24U) and Fuel Injectors (from any Honda/Acura 88-91). You must realize the B18B and B18A are essentially the same engine just from different years. Good luck, and dont be afraid to PM me with questions.
