b18b (jdm) vacuum?
Discussion in 'HYBRID -> EG-EK / DC' started by stoopidb18eg, Apr 28, 2011.
  1. stoopidb18eg
    stoopidb18eg New Member
    Ok, car runs great but when I pound on it the cel comes on. The car wont run any different and soon as you turn it off and restart it the light will stay off even if you drive it 100 miles it wont come on unless you take it above 6k rpm. I haved noticed there are some vacuum lines missing and there is no charcoal canister. Could this be my problem? Is so can someone please post up a detailed diagram and tell me what all I need? Thanks for any help. Sorry I forgot to mention this is a jdm b18b in a 93 hatch
  2. Briansol
    pull the code when it comes on. that's really the only way to know whats going on.
  3. stoopidb18eg
    Ok I pulled the codes this morning. Im getting code 3 which is manifold absolute pressure, and code 7 which is tps. I get the 7 and then the 3. I believe its 2 seperate codes because 73 says misfire but I dont think thats it the car runs too smooth.
  4. stoopidb18eg
  5. Matts96HB
    Matts96HB . Moderator VIP
    if it were 73, it would be seven long flashes, followed by three short flashes.
    in the third pic, i see a spot for a vacuum line that has nothing on it. it looks like it could be for the TPS, but i cant really tell. if you post some more pics i might be able to give you some better advice. also, it appears that the sensor you are holding is a MAP sensor (possibly)
  6. RHDism
    RHDism Right Hand Drive guru
    Purge solenoid and Map in the photos.
    Looks like they ran the vacuum line direct to the map, bkoz of the different intake mani.
    Some chipped ecu's are programmed to illuminate CEL at redline, but should turn off once throttle is released. I would try swappin out the TPS and see if the problem continues.
    As far as your missing vacuum lines and canister, somebody was going for an engine comp. clean up and possible wire tuck. :confused:
