b18b obd1 into obd2 ek hatch helpppppp!!!
Discussion in 'Civic and del Sol - EG and EK' started by ekb18b, Jul 9, 2010.
  1. ekb18b
    ekb18b New Member
    ok i jus dropped an obd1 b18b fully rebuilt with a gsr tranny into my 96 ek hatch(obd2)
    i got the motor and tranny in and everything hooked up i modified the stock obd2 harness and used a jumper harness for dizzy and ecu to run the obd1 engine
    tried to crank it off and few problems
    -when turned on the on position fuel pump relay does not click and fuel pump doesnt come on so we tried a wire direct from battery to pump and pump works soo.....
    -now that we got fuel we tried to start it and it turns over but doesnt fire so we checked for power goin to dizzy and got that jus no fire
    i checked all wires and it all looks right i compared the wiring diagram from haynes manual for 96 civic(obd2) to the 92-95 civic(obd1) and to the obd1 integra and all sensors plug in correctly that are needed
    anything i done wrong?
    ANY IDEAS?
    and check engine light stays on but not sure why
    if i want to run a check on the computer how do i go about checkin it? as an obd2? or obd1? remember its obd1 engine dizzy and ecu but on a obd2 harness
  2. ekb18b
    ekb18b New Member
    please
    pleaseee anybody?
