b18b rods?
Discussion in 'Engine Building' started by b18vtecrx, Apr 1, 2004.
  1. b18vtecrx
    b18vtecrx Senior Member
    i just picked up a b18b and i was wondering what rods i should get? i was looking at the eagle rods but im not sure which woul be best for boosting...H beams? and should i get them at stock length?
    now the other question- i just finished swapping a b18b1 into my crx and the motor i got today has b18b printed on it not b18b1 so can anybody tell me why the new motor doesnt have the 1 at the end like my old motor? thnx for all your help i appreciate it a lot. peace -mike
  2. pissedoffsol
    no 1 on the end = JDM
    get stock length rods unless you are doing a custom stroke crank or custom wrist pin height pistons.
    best for Boosting = Pauter. :)
    but the egales will most likely be fine for your setup.
  3. Import Builders
    Import Builders Senior Member
    LA, California
    IB Spec H beam turbo rods.
    9 MM ARP rod bolts, torque to 38 lbs.
    Similar design to eagles, but with better bolts.
    Jeff
  4. b18vtecrx
    pissedoffsol- where can i find these "pauter" rods?
    and my other question for everybody is what pistons are recommended for boosting my b18? please get back to me asap thnx -mike
