B18B Stopped Running! Help!
Discussion in 'Integra' started by ballerxforxsho, Mar 5, 2010.
  1. ballerxforxsho
    ballerxforxsho New Member
    alright, so its a 95 teg, LS head. he was driving it and it just quit randomly and wouldnt start again. prior to this, car had no problems at all and has had thse mods on it for awhile. when it stpped running we changed the plugs and wires. havent done anything else. heres a list of mods it has incase anything might throw it off from running. ANY SUGGESTIONS ARE GREAT!
    -4-2-1 header, into test pipe, to stainless steel Greddy exaugst, no cat no nothing.
    -AEM cold air intake
    - idk what else haha
  2. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
    is there power to the car? does it turn over? do you have fuel? do you have spark? a lil more info would help
  3. ballerxforxsho
    yes theirs power, yes im almost def dure theirs spark, and we just replaced the whole fuel filter system cus we thought that was it.
  4. civichatch1988
    civichatch1988 Ef hatch
    Seattle
    Timing belt break? And I would check for spark and fuel just to rule it out
  5. DESPAIN
    flower mound TX
    timing belt is what i was thinking also.
  6. ZCpowerdSI
    ON, Canada
    Probibly didn't even look at the timing belt. lol
  7. ballerxforxsho
    yeah sorry, were not all integra experts here. and what about the timing belt? is it one peice? yes
  8. ZCpowerdSI
    ON, Canada
    lol i aint makin fun of anybody dude
  9. ballerxforxsho
    @ZCopweredSI - if your gonna hate hop off the thread. you ask me if it has fuel, spark and if it turn over like im a dumbass. like i didnt check that or anything. bottom line, stop hating or get off.
  10. EF4Life
    EF4Life New Member
    sigh
  11. dc4dude
    dc4dude Member
    chicago, il
    check to see if the injectors pulse when you crank it. if you have spark and fuel pressure, you might not be getting a signal from either your crank or cam sensor.... check the ground cable that goes from the valve cover to the radiator support, and also check the ground cable that goes from the passenger side frame rail to the trans case bracket.
  12. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    hes not hatin dude hes helpin but if u wanna act like that u are a dumb ass.
    Now when u try to turn it over does it sound like the cam gear is free spinning real fast? have u pulled the plug out to see if its getting spark? have u taken a fuel line off and turn the car on to see if the fuel pump is working? ur not giving a whole lot of info for us to help u ur coming in here demanding help pretty much and we are trying but ur acting like a DUMB ASS say zc is hatin on u greenhorn.
  13. ballerxforxsho
    yeah it has fuel, and replaced the fuel filter and has pleanty of fuel pressure. and it has like weak spark but we just replaced the sprak plugs and the wires are new. is it possible the ignition coil is bad?
  14. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Yes timing belt is one piece. Have you checked the timing belt yet? Take the top plastic timing belt cover off (a few small bolts) and see if its in one piece still. What about the plugs wires? Are they for your LS or for some other motor? (like a DOHC VTEC)
    And BoostedHatch is kinda right about the spinning....but if the timing belt snapped...it would be the crank spining and no cam gears moving. It would spin pretty fast too (faster then it did when it was running)
  15. monty92
    monty92 New Member
    regina, sask
  16. ballerxforxsho
    ive checked the timing belt, its fine, distriutor is brand new. goin to replace the fuel relay and see if thats it
  17. CAFROG
    NOR-CAL
    Plug wires are the right ones? I doubt this is it though...it would still turn over....I think but you saying there is a little spark makes me wonder.
  18. ballerxforxsho
    theirs spark, and yeah the plug wires are right.
  19. CAFROG
    NOR-CAL
    Main relay?
    Well thats all I got good luck bro
  20. ballerxforxsho
    thats what im about to replace. thanks man
