BlueDemon
1993 eg civic coupe dx manual trans swapped with a 96 integra b18b manual trans with correct ecu.
Alright, got it started finally today after finding a ground issue! But now it wont start again..
Entire fuel system is good and you can hear fuel pump going, spark is good obviously it started once, starter has been tested and battery is brand new. Compression is tested at hmotorsonline before they ship it out.
Have some questions though
1) Car had one map sensor that came with it, motor has one sensor installed which do I use? And which one of the wires am I supposed to use? (there's two sensors and two plugs)
2) o2 sensor on the bottom does not hook straight up how do I fix this??
I'm going to attach a video of it as well. I swapped this several weeks ago and yet to get it running...
http://s303.photobucket.com/user/DwreckChev/media/VideoMar2330624PM_zps39ebfe06.mp4.html
