B18b valve/head
Discussion in 'Engine Building' started by civicblazin, Apr 23, 2009.
  1. civicblazin
    civicblazin New Member
    I am purchasing a B18b with bad valves. I was going to replace them with stainless steel or titanium, but after talking to a friend, he just told me to get a new head. Which one should I go with? Any help on locating either parts would help.
    thanks
  2. red91efhatch
    red91efhatch New Member
    Albuquerque
    really no need to replace the head unless its really damaged, sometimes you can find a loaded head for less then it would cost to replace the valves though....just run a google search ebay etc I got lucky and found a full set of valves on ebay for $40 good luck
  3. 97hatch
    97hatch ?
    Anderson IN
    what are your goals for the engine and that will help us give you advice
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    All depends on what "bad valves" means.. Why exactly are they "bad"?
  5. civicblazin
    The guy i talked to didnt exactly tell me wat was wrong with the valves. But i wanna build it so it pushes around 200hp, and i want more torque (no turbo, supercharger)
