B18B vs B18c5
Discussion in 'HYBRID -> EG-EK / DC' started by here2chill, Mar 3, 2004.
  1. here2chill
    here2chill Junior Member
    I am still looking at doing a swap into my 92 hatch automatic. Which swap/auto conversion would be easiest and cheapest off the hop? Which motor would have better potential for whp with upgrades?
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    obviously the B18B swap is going to be less expensive, when you consider how plentiful and cheap they are compare to the ITR motor- The auto to manal conversion is going to be the same with either motor, since the both came stock with hydro trannies- The real choice is up to you- The B18B is a great candidate for turbocharging right out of the box, while the ITR motor makes 200hp- it's more or less up to you and your wallet :shrug:
  3. E_SolSi
    are you kidding????????????
    welp first an auto to manual conversion will be the same regardless of what engine you use
    cheapest?????
    welp lets see the LS engine can be had for $1000-$2200
    the ITR engine goes for $4600-$5500 all day
    im sorry but this question just sucks ass
  4. driverunknown
    driverunknown Senior Member
