b18b ???
Discussion in 'Integra' started by ls vtec teg, Feb 24, 2010.
  1. ls vtec teg
    ls vtec teg New Member
    hi
    I have b18b non manual and I want to make it vtec
    so which head is better for it b16b or gsr and which one is chipper ?
    and I have to buy the ecu ? or it is olready with the head ?
    finally how much it cost if I do it all in the garage?
    Thanks
  2. sussexboiiz
    sussexboiiz New Member
    on the real shit ill get da gsr head but if ur money not rite get the b16 but gsr is better
  3. HA Motorsports
    HA Motorsports New Member
    With all due respect here... Do you mean which one is cheaper? Please do a search and you will find prices on this everywhere.
    Will the ECU come with the head? Ask the person you are buying it from....
  4. ls vtec teg
    thanks guys for reply but I ask because her no respect for honda only nissan and toyota lol and its very hard to know the price in 2010 ?so can you help me . my I think the price of the head and the esu is 700$ is that right ?
    so the gsr is better I thought that b16b is better because the cop 10:6 but gsr is 10:1 thanks for the answer.
  5. suspendedHatch
    suspendedHatch audio/security
    Don't swap the head. That's a big mess and you sound like you have no clue what you're doing or even talking about. A million things can go wrong with LS/VTEC. I suggest you swap the trans for a GSR trans, then turbo the motor. After that, get some cams that work well with a turbo and have the ECU tuned professionally. You will never regret having a non-VTEC motor.
    The GSR is more of a street motor and the B16 is more of a top-end motor. Don't confuse B16A with B16B. B16A is much more common. B16B is a rare Civic Type R motor and you don't want it especially just for the head.
  6. ls vtec teg
    First thank you friends
    about the turbo its not allowd her because of that I want to make it vtec
    and I well change head , water pump , comprsion not only the head and the trans hasn't the power like the vtec
    right ?
  7. ls vtec teg
    and what ever the price
    what is better gsr head or b16a ?
  8. Magana559
    Magana559 The Warden
    fresno Ca
  9. ls vtec teg
    thanks manga I didn't think about the bolts
  10. suspendedHatch
    GSR and B16 heads are completely different.
  11. BrutalB83
    Rochester Hills, MI
    Where are you where a turbo is not allowed?
    And no, a transmission unto itself doesn't generate any power, but different transmissions are geared differently, and some can allow for quicker acceleration because of the gearing...
  12. Magana559
    fresno Ca
    they flow pretty much the same look.
    bolt pattern on the intake side is diffrent too, Also the GSR head has quench pads which ward off detonation. Also the gsr head is cheaper because everybody talks shit about it.
  13. Magana559
    fresno Ca
    Sounds like you dont know what the hell your talking about or your living in the late 90's.
    whats so hard about adding a sandwich plate befor your oil filter, unscrewing a plug in the head, running a braided stainless steel oil line, buying a LS-vtec gasket, buying LSvtec dowl pins, wiring 3 wires for vtec, and a tune?
    if you want it reliable you have to rebuild it with arp rod bolts and high comp pistons and a nice new set of bearings.
    stop saying things you know nothing about. if you do it right you wont have any problems.
  14. D16SiHatch
    D16SiHatch New Member
    for the price of a reliable ls/vtec you might as well just purchase a gsr.
  15. BrutalB83
    Rochester Hills, MI
    You could make that argument, yes. But there's a reason why people build LS/VTECs aside from just the fact that they already had an LS engine. As a result of using the LS bottom end you often get more torque then you would with just a straight up GS-R...
  16. ls vtec teg
    so I well get a gsr head , water bump , rods bolt and Ecu. after 2 month or less
    so thanks guys for helping me ;)
  17. Magana559
    fresno Ca
    you will spend well under 1k for a reliable LS-V and make so much more power for the price VS the GSR.
  18. Magana559
    fresno Ca
    Cool, no problem! keep us updated and remember to tune that engine! the most important thing in a good LS-V is the tune.
  19. D16SiHatch
    factor in all the price of parts and install, plus the tune.
    i just don't see it costing sub $1000 to get it done.
    how so? they both have the same displacement.
  20. BrutalB83
    Rochester Hills, MI
    No, actually they don't. They're close enough that we refer to both of them as 1.8 liters, but actually the non-VTEC engines displace about 35cc's more then a GS-R does. The rod/stroke ratio is different also...
