b18b1 - 91 civic
Kadoj
i got a 91 hb std and am thinking about putting a b18b1 into it, its from a 3rd gen integra so does that mean i have to go from obd2 to obd and also what kind of mount kit do i need. Is this a tricky swap or is it pretty straight forward?
The swap is pretty straightforward. You will need a mount kit. You won't necessarily have to go from OBD2 to OBD0 (not all the 3rd-gen Integras are OBD2; 94-95 are OBD1), but you will have to do some type of wiring conversion...
hello everyone i have a b18b and a gsr head does anyone one know the problems i will run into such a deck clearance valve piston clearance any thing helps thank you
Research. This forum alone has a wealth of info on LS/V swaps. Just take your time and read through the threads, nearly all your questions can be answered by reading some of the other posts.
Try research and starting your own thread my friend. Thread jacking isn't in nowadays. :D
