B18B1 Help
RotiEatter
I may be getting a B18B1 Automatic for very cheap. lt won't come with the transmission.
What would i need to make it work for the 5 speed, there is a 5 speed in my 92 DX hatch. D15B7 still, heh.
I was assuming I would just need a 5 speed ECU and need to bolt the manual transmission up to the block.
You need a B series transmission, but you don't need to buy another ECU. You can reuse the automatic ECU by converting it to manual. There's one or two jumpers that need to be moved inside. I don't remember which ones though.
If you need a OBD1 PR4 I have one from my 93 LS (manual) that I would part with, PM me if you are interested.
