b18b1 into 97 civic ex
Discussion in 'HYBRID -> EG-EK / DC' started by elvis8310, Oct 12, 2007.
  1. elvis8310
    elvis8310 New Member
    Stuttgart
    I have a blow motor in my 97 ex and a free b18b1 with tranny, ecu and all other parts. It was dropped out of a totaled car. What parts will I need to mount it up and how do I rewire the car right? Are there any companies who see the converted wiring? I have never done a vtec to non-vtec before so all help please. I need to order all the parts right away to get back on the road fast.
  2. BrutalB83
    Rochester Hills, MI
    If you want a plug and play harness check out Rywire - Online Store.
  3. elvis8310
    Stuttgart
    Ok what about cv shafts, shift linkage and motormounts? I would also like to keep the AC if possible.
  4. Matts96HB
    Matts96HB . Moderator VIP
    You need:
    Integra axles
    Integra shift linkage
    99-00 civic si upper driver side mount
    99-00 civic rear t-bracket
    Integra ECU, p75
  5. elvis8310
    Stuttgart
    Ok have all of that. What else? Do I need to buy one of these motor mount kits like hasport or avid racing sells?
  6. elvis8310
    Stuttgart
    Ok I have those parts. How about one of these motor mount kits from hasport or avid racing? Do you need these or what are they for?
  7. elvis8310
    Stuttgart
    Also how do I know if this is an OBD1 or OBD2 b18b1? It has a p75-a01 ecu any help please with pics if possible.
  8. BrutalB83
    Rochester Hills, MI
    What year car did it come out of? 96+ is OBD2.
  9. elvis8310
    Stuttgart
    That is my problem I do not know what year car it was. It was planned to go into my 92 civic and it never mattered for that swap. I know it has a y80 trans and p75 ecu and b18b1 on the block. Is there anyway to tell other than that if it is a 1 or 2? The reason I want to know this is so I don't waist money on an OBD2a to OBD1 ECU Conversion Harness. I want to order all swap parts today to get them in the mail so I can do this fast. Also would the avid racing or hasport motor mount kit make it easier to mount this engine in my 97 civic?
    Part I already have.
    axles
    shift linkage
    ecu, p75-a01
  10. civic4g63
    civic4g63 New Member
    fl 1 hot place
    ok for direct plug in play u will need to transfer some stuff from the singlecam such as ivac valve, also u need 90 non abs integra axles with a dc2 midshaft, any bseires shift linkage, aslo u will need the 99-00 si rear bracket,top tranny mount,any bseires lower tranny mount,and 99-00 si timming mount on the engine, any bseires ac bracket will work but u wont b able to use your single cam ac compresser, also u will need a dizzy for your year car ex: 97 civic u will need a 96-98 integra dizzy and it will plug in will no problems even though your car has a vtec harness, u can also use a 98 ls ecu if u want to keep it obd2, u will need the upper and lower radiator hoses out of a 90-01 integra, cause the single cams hoses will not work with the ls. but u can use a jumper harness with a chipped dx or ls ecu an u will b ok, lmk cause i did the swap in my 98 ex, but know i have a gsr now, one last thing if u want to keep your ac u will need a delsol ac bracket an u can use your single can ac compresser to keep ac in your car
  11. civic4g63
    fl 1 hot place
    i can post pics of my swap if u want to see lmk
  12. elvis8310
    Stuttgart
    Please post pics. So even with the mount kit sold by hasport you still need the
    99-00 top tranny mount
    upper and lower radiator hoses 90-01 integra
    delsol ac bracket
    So don't use the ls wiring harness, use the civics one right? I thought you could use the one on the b18b1 and just plug it in? Is there a problem with doing the rywire obd2 to obd1 jumper? Will I still need all the parts above if I buy the mount kit from hasport?
    HASPORT Billet Mounts
  13. elvis8310
    Stuttgart
    Hasport Performance Online Store
    Rear engine bracket for 96-2000 Civic with B-series Engine swap
    Lower Transmission Bracket for 92-00 Civic with B-Series Engine Swap.
    AC Bracket for 92-00 Civic with B-series Engine Swap
    Axle set for use with B-series engine swap
    Engine mount kit for B and D series Fits B18B, B20, and B16
    OBD2a(97 ex) to OBD1(p75) ECU Conversion Harness, who would sell this?
    are there any other parts I would need to buy to do this right the first time? I want to order parts tonight for my swap so I can get back on the road as soon as possible.
  14. BrutalB83
    Rochester Hills, MI
    What does the valve cover look like? If it's smooth and flat on top, it's a 96+ and OBD2. If it's got raised areas then it's pre-96, and it's OBD1.
    Here's a pic of my OBD2 cover for reference:
  15. elvis8310
    Stuttgart
    it does not look like yours
  16. elvis8310
    Stuttgart
    what year axles and shift linkage? I have all the shafts out of the car it was pulled from. I think it was a 94 or 95.
  17. civic4g63
    fl 1 hot place
    just use your civic harness and injectors and iavc valve and a 96-98 integra ls dizzy and it plugs in. u will also need to extend your 02 sensor cause the b seires o2 sensor is in the back of the header, also if u got a jumper harness u should use it, obd1 ecu any chipped po6,p75. dont get the hasport mounts its a waste of money.
  18. elvis8310
    Stuttgart
    So keep the stock wires but use the p75 ecu. What and who can chip it for me(the ecu)? Were can I buy the mounts for the engine as you say don't buy the hasport kit.
    do you have a link to buy the
    iavc valve
  19. elvis8310
    Stuttgart
    Ok, does anyone talk on this site? Over 90 people have visited but very little help has come my way. Come on people I am asking for help to get my ride done right the first time.
  20. civic4g63
    fl 1 hot place
    i bought my mounts from the honda dealership, all the mounts came out to about 160 which is a alot chepaer than hasport and that i know the mounts i have is going to work.
