serrilion
In my own little world!
So have a b18b1 in a 92 CX hatch...
The car runs and drives fine to a point
It runs and idles perfect but if you go to get on the gas in 1st gear it almost acts as if you hit fuel cut under a heavy load of Throttle... Now if you stay at 3/4 throttle it will run fine...
under a full load it will spit and spudder and kick you out...
I have checked the following
Plugs
Wires
Cap
Rotor
and The dizzy itself
The car is currently running in dead of winter w/o termostat as the old one got stuck closed and I just cut out the center of it...
Now it being a fuel injected motor, would this cause this problem do to the motor thinking its not warm enough>
thoughts
thanks
Plugs
Wires
Cap
Rotor
thoughts
thanks
