B18B1(Should he go OBD-0 to 1,2,2a???
B18B1 in a 90 HB and needs to buy ecu so should he go OBD-1 or 2,2a? What advantage or disadvantage?
first, you are in the wrong forum.
second, find an ECU from a 90-91 integra (PR4) and stay OBD0
Pro's - easy... cheap... reliable cuase its how the car came. I swapped a 98 B20B (OBD2A) into my 90 Integra (OBD0). Im running OBD0 and dont have any problems...
Con's - not as easy to tune...
thanks Brian..the B18B1 is off a 94 teg and was OBD-1. If I go OBD-0 I'll need to change dizzy. I should go OBD-1 just to run it the way it was meant to. Shouldnt I?
I had a 91 civic with a b16a2 obd-1 and kept it obd-1. all i did was rewire my dash harness to obd-1, worked fine to me.
