Gnarphantom
Located in Mankato MN. Hit me up at 507 382 7680
PRICE IS $800
Let me start with what I DON'T have, and what you will need to complete the swap.
DOES NOT COME WITH -
ECU
missing half the linkage
Axles
Dizzy jumper
Now on to the swap -
B18B1 complete long block 105,XXX guaranteed to run
OBD1 Dizzy
B series Starter
OBD0 Alternator
Half Shaft
OBD0 MPFI engine harness (not pictured)
Cold Air Intake (not pictured)
AZ Race Mounts
Half of the Hasport Linkage with short throw and Energy Bushing
ACT Pro Light Flywheel
BNIB Clutch Masters clutch with throw out bearing
Cable LS Trans
T Bracket
Clutch and Throttle cable
Jegs oil filter relocation Kit
Two extra LS valve covers
The Bad -
Pulley is chipped - I have a CTR one for $40 extra
Needs oil pan gasket
NO TRADES AT ALL
I do have an OBD1 Vtec Dizzy and Oil line that can go with too if someone is planning to do LS/Vtec. Whoever buys this gets a sick discount on other parts that I am trying to get rid of.
Pics -
I also have a 91 CRX SI Shell I want to get rid of. Shell needs paint and a windshield. DO NOT CONTACT ME UNLESS YOU HAVE CASH FOR THIS CAR!
Just did -
Ksport Coilovers
Skunk2 front camber kit
Buddy Club rear camber kit
Blox lower control arms
Wicked Toe kit
Energy Suspension Trailing Arm Bushings
Blackworks Extended Studs and Lug Nuts
16" Gold GT3s with brand new Falken 912's
New brakes and wheel bearings and undercoated in the rear
Here are some pics - call if actually interested-
PRICE IS $800
ECU
Axles
Dizzy jumper
OBD1 Dizzy
B series Starter
OBD0 Alternator
Half Shaft
AZ Race Mounts
Cable LS Trans
T Bracket
The Bad -
NO TRADES AT ALL
Pics -
Just did -
Ksport Coilovers
Wicked Toe kit
