trigun7469
Member
hi I have read quite a few posts on the subject and I am going to attempt to swap a B18b1 (OBD1) into my 93 cx
I am aware that I need the complete swap which is long block, trans, mounts, axels, wiring, Ecu.
after reading many posts some people have different opinions on the subject matter
D-series accelerator cable will work while others disagree and say that you need the integra? any bottom line answers?
I have a stock exhaust system for a CX will I need to swap cats and get a integra cat or will everything bolt up? I heard there was a 7 inch gap, I can't verify that info.
On to brake setups, I am doing a complete swap to GSR brakes, everything suspension wise will be swapped, my question is will the E-brake cable have to be a GSR cable or will it work as it current setup?
Engine rebuild kit <-- is this the cheapest engine rebuild kit?
