i got a 98 b18b1 and i need to know what car would be beter to put it in a 93 or 97 hatch also if i went with the 97 would the p75 plug up to where the p2p plug up or can i run a harness to convert in to an obd1
97 would be cheaper due to wiring but i know their are two sets of obdII computers i think they change in 99 or 00 but any way a 97 should make it a snap-on swap, if u swap it in a 93 be prepare to spend another 300 for the wire convertion kit and around another 300 for a obdI ecu
my mistake u will only need to buy a ecu an obdII engine should plug right in a 93 civic, i put a 98 gsr in my 92 civic all i needed was a obdI ecu and nothing else
