b18b1 swap
90civicb18b
Ok so i have some questions. i have a totalled 96 integra with a b18b1. i want to put the b18b in my 90 honda civic 4dr with a zc dohc 1.6 in it. what parts do i need for the swap. i was told to swap everything under the hood to obd1 and use a jumper. what all do i need to swap under the hood and what else is needed to make the swap run....
id go with a obd 1 ecu and a 91 dizzy and you need aftermarket mounts and shift linkage or you can cut the linkage and weld it shorter. i do the swap all the time i Hvae it in my crx si ef 4 dr and ef wagon 2wd i love the b series.
I think you also may have to either modify your harness or use a different alternator and I think the OBD2 injectors wont clip to your harness
