b18b1 turbo oil leak
Discussion in 'General Tech and Maintenance' started by MikeWarren1026, Mar 16, 2008.
  1. MikeWarren1026
    MikeWarren1026 New Member
    Okay so i just rebuilt my b18b1 in my 95 civic coupe. Everything is back together the car runs pretty good has a little rough idle but i think i know why. My problem is that im getting a little oil thats coming outta the bottom of the dip stick tube. The car isnt blowing the dip stick tube out its just leaking right at the bottom where the tube goes into the block. Also for some reason im running a 3 bar map sens and im still hitting limp mode. if the car sees anymore than 5psi of boost it totaly runs like shit. the motor is built to handle upwards of 12psi but for some reason i cannot get the map sens to work right. Is there anyway to just trick the car other than using a missing link?
