B18B1 Turbo Project
Discussion in 'Forced Induction' started by AcUrA_TuNeR, Mar 25, 2004.
  1. AcUrA_TuNeR
    AcUrA_TuNeR Junior Member
    I'm working on a 300HP B18B1 Turbo and I need help getting started... What should I check first??? What parts will need to be changed??? In what order??? That's my first project so... I need to do my lessons :roll: Thx for your support :D
  2. pissedoffsol
    technically, nothing NEEDS to be changed.
    there's plenty of folks running bione stock motors making 300 whp.
    but, they are TUNED and FUELD precisely.
    and that, my friend, is the key to any turbo setup
  3. AcUrA_TuNeR
    That's the reason why I'm here to learn how to do it properly... I need some technical facts to help me tuning everything precisely... I know that tuning is the key for a Turbo set up... What I want is to UNDERSTAND what I'm doing on the engine... If I put that, it will do that and I'll need this to do that... You know what I mean!?!?
  4. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    wasn't he talking more along the lines of changing the intake with I/C piping and his stock exhaust manifold with a turbo manifold, or did I fail to comprehend his question?
  5. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    yeah homie I catch your drift, but if i were to sit here and write a list for every part you can put on the car, what mods would be necessary and what it would do, anyone of us could easily spend all night typing- try to ask more pointed questions, ie "what boost level (psi and cfm) will i need to run this amount of horsepower"- or "what is the best way to precisely control fueling?"
  6. AcUrA_TuNeR
    Ok thx for the tips...
  7. AcUrA_TuNeR
    For a 300HP B18B1 Turbo setup, what boost will I need to pull???
  8. pissedoffsol
    boost is pressure and does nothing really (psi)
    air volume (cfm) makes power
    more dense air (v/a) makes even more
    10 psi on a small turbo cfm flow rate = small gain
    10 psi on a huge turbo cfm flow rate = huge gain
  9. AcUrA_TuNeR
    How can I find the good CFM for a given situation??? and what is v/a??
  10. pissedoffsol
    v/a = me needing more sleep. lol
    Density relates the mass of a substance to its volume through the formula: D = M/V
    (D)ensity = (M)ass / (V)olume
    in non- technical terms, the "more" air you compress (via a turbo) into one place, the more air actually gets in per given space.
    lager turbo's compress MORE air into the SAME space as smaller turbos, thus, increasing the actual amount of air avaible to combust.... and combustion when mixed with fuel and spark = power.
    the problem is that you are trying to figure out a good psi to hit 300 hp.
    psi should be the result...
    or, it takes X psi on Y turbo to hit Z power
    we have 1 variable filled in- Z
    X * Y = 300
    well, its nto really multiplication, but thats the best way to write it.
    here's an example:
    if you run Y as a to3/to4e, it will take, X psi.
    if you go smaller, it will take X+5 psi
    if you go bigger, it will take X- 5 psi
    does that make sense?
