b18b1 turbo???
Discussion in 'Civic and del Sol - EG and EK' started by phoenix19l, Aug 14, 2008.
  1. phoenix19l
    phoenix19l New Member
    charleston, sc
    Is it possible to boost a b18b1 stock engine? what mods should be done without tearing into the block or head? how much boost can I push? I am not looking for extreme hp gains. I do expect, however, about 30-50 hp. Do i need to upgrade the injectors and fuel rail? if so, to what floww rate or CC? I just need the specifics for about 7-10 lbs of boost. nothing more than that is neccessary. Will i need to upgrade the ignition? if so, what is recommended? also, what FMU is recommended? and help would be appreciated, thanks in advance.:confused:
  2. newb
    newb phresh VIP
    Backwoods Northwest
    :search:
    Its not that hard.
  3. phoenix19l
    charleston, sc
    That doesnt answer the question.
  4. George777
    George777 ^^ Likes Bewbies
    With your mom
    But research does...
    Don't expect to come on here and be fed information with a silver spoon. Research things like the rest of us...
  5. newb
    newb phresh VIP
    Backwoods Northwest
    Fuckin :werd: You arent the first person in the world to build a turbo B18
  6. phoenix19l
    charleston, sc
    I agree but I haven't seen anything that specifies how much boost I can push on a stock block. Every thread that I have read involves opening up the block.
  7. George777
    With your mom
    IIRC, a bone stock LS can push about 15 psi before it takes from the integrity of the motor. But its been a long time since I have looked into it and could be wrong. It also depends on what type/size turbo you are going to use, and other things. Your question is, at best, vague without more information.
  8. phoenix19l
    charleston, sc
    Garrett T25 turbo, from a nissan SR20DET. small turbo. It should max out before or right at the peak powerband of the b18b. My main goal is to avoid as much lag as possible. I am just trying for useable power.
  9. newb
    newb phresh VIP
    Backwoods Northwest
    Dont worry about your boost levels. Focus on a power output then boost until you get to that level. I say dont go over 300 horse on stock everything, but there are ppl who push into the 400's. I say 300 horse assuming youve got fresh bearings, rings, fastners, and all like that. In the long run, everything depends on the condition of the motor. At the very least you should get ARP hardware, OEM Honda bearings, and OEM Honda gaskets. At that point you wont have any problems with boostin to about 300 horse. And dont skimp on the tune. A bad tune will give you an expensive boat anchor in a hurry.
  10. phoenix19l
    charleston, sc
    I am looking to attain some sort of boost without breaking into the engine. no new seals. not new rings, cylinder walls probably a little scratched. motor with 62000 miles on it. I am not looking for anything close to 300 hp. more like 180-240.
  11. newb
    newb phresh VIP
    Backwoods Northwest
    In your blog you use the word reliably, if your not willing to replace anything on the motor you have, and you want reliability, then dont boost it at all. If your actually not worried about reliability too much then Id say keep it right at 200 horse or less. But, like I said earlier, the amount of power any engine can handle is dependent on how worn its parts are. With that said, no 2 engines are alike, so yours may handle the extra power ok, or it may not.
  12. phoenix19l
    charleston, sc
    Fair enough. I drive this as my daily driver. So I do need some sort of reliability behind it, thus, the low expectations of a turbo. When this engine kicks the bucket i will get a new engine and later on a JRSC for it. But that is much later down the road. I am just looking to have a little more kick from my LS.
  13. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
  14. newb
    newb phresh VIP
    Backwoods Northwest
    It bad enough that you act like a douche in your own threads, but how about you keep that shit outa the threads that other ppl start.
  15. George777
    With your mom
    Postwhoring. One of the many services he offers
  16. driverunknown
    driverunknown Senior Member
    62k miles is nothing. Boost away at 7 psi. Get a real good tune from whatever tuner uses hondata or something similar. My setup pushes what you want plus I get 30 mpg :)
    For injectors 440 cc should be plenty.
    Fuel rail should be fine.
    You might want to get colder plugs, but if your tuner is worth a damn he'll know what plugs to go with.
    A big intake filter is a must. Keeps the turbine from getting damaged
    A full 3 inch exhaust does wonders as well.
    Your ignition can handle way more than your goal so leave it alone.
  17. BrutalB83
    Rochester Hills, MI
    LOL! It's funny because it's true...
  18. Kevoh
    Kevoh New Member
    Austin, Texas
    I'm looking for more or less the same thing on my
    94 accord lx.
    I know I changed my head gasket, timing belt, water pump and all that nonsense
    about a year at most ago and I don't really push it as my suspension's runnin old.
    Do you think I would be able to pull about 9psi without messing up my motor??
    and if I could how reliable would it be because it is my DD.
  19. ilubmyEG
    ilubmyEG New Member
    Utahrded, united states
    Dont thread jack :ph34r: yeah ninja!
  20. phoenix19l
    charleston, sc
    That pretty much answered every question I had. Thanks. I do have one last question. What kind of short shifter would I throw in there? shorty from an integra or civic?
