b18b1 with b18a1
Discussion in 'HYBRID -> ED-EF / DA' started by londoncrx, Mar 1, 2009.
  1. londoncrx
    londoncrx New Member
    will a b18b1 work with my b18a1 wiring harness and ecu
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what year b18a1
  3. londoncrx
    90. 93. I think the b1 is. 94
  4. D16SiHatch
    D16SiHatch New Member
    90-93 still doesn't narrow it down. need to know if its 90-91 or 92-93. if its 90-91 then you'll have to use your a1 dizzy on the b1, and swap out the obd1 injectors for the obd0 ones on the a1. if your car is a 92-93 then you can leave all the components as they are on the b1.
  5. londoncrx
    how do i find out what year its from
  6. D16SiHatch
    not the year of the b18b, the year of your car that you want to put the b1 into is what you need to figure out. if the b1 is 94-95 then its obd1, if its 96+ its obd2. if it is obd2 you will notice extra evap equipment on the intake manifold, and a crankshaft fluctuation sensor located just above the crank. if the b1 is an obd2 engine you will need to downgrade to either obd1 or 0 depending on what year your car is.
  7. londoncrx
    oh its a 90 crx dx i think ,but it was already swapped so yeh
  8. londoncrx
    ok let me say this if my motor is hydrolocked should it still turn over with the plugs taken out
  9. D16SiHatch
    yea, and water should come shooting out. unless you like severely broke something to the point that the crank can't even rotate anymore.
    and let me get this straight. are you tryin to say you have a b18a1 harness in your crx? i'm lost. or maybe you think that its a b18a1 harness because thats whats in there. i suppose that might make sense. basically somebody converted your stock harness to mpfi and then hooked it up the b18. so basically you need to figure out whether you're running obd0 electronics or obd1. if the ecu has a clear window in the center for the flashing cel led, then its obd0. if there is no window in the ecu, then its obd1.
  10. efhondakid
    Akron-Canton, Ohio
    If the motor is hydrolocked Im willing to bet that it bent some valves.
  11. londoncrx
    ok well there is a window but i dont know what harness was used i just know its a b18a in it
  12. D16SiHatch
    ok well then all they did was convert the dx harness to mpfi and then hook it up to the b18. since you have an obd0 ecu you'll want to move the old injectors and distributor over to your b18b.
  13. londoncrx
    ok i see i just move that stuff over and it will be fine
