b18b1
Discussion in 'Engine Building' started by rogelio93, Jan 13, 2011.
  1. rogelio93
    rogelio93 New Member
    im thinking in swapping a b18b1 on my ej 7 is that a good investment
  2. E_SolSi
    maybe
    maybe not
    thats a very generic question and it doesnt have a direct answer
    depends what you are looking for
    what do you want out of it
    what are your short and long term goals for it
    what is your budget
    what do you plan to use it for
  3. Matts96HB
    Matts96HB . Moderator VIP
    also depends on how well the swap is done. a hacked-to-shit swap will probably not be worth your time and have reliability issues. a well done swap will not.
  4. rogelio93
    im planning on putting p30 pistons better breathing bild the head and turbo it maybe 6lbs of boost
  5. rogelio93
    just want a cruiser that looks good and wont stay behind
  6. Matts96HB
    id recommend a b18b1 swap and just turbo the stock engine. once you open up the bottom end, you sacrifice the reliability that makes hondas so popular.
  7. rogelio93
    for real i might just do that
  8. Matts96HB
    yeah its just a suggestion, theres many routes you can go. in fact, the stock d-series can be rebuilt and make some decent power if you know what youre doing. but then again, once you rebuild it, reliability comes into question.
  9. btk2334
    btk2334 New Member
    Bolt on turbos on b18b's are nice... factory low compression and the best displacement since they have the longer stroke crank
  10. Matts96HB
    lower compression isnt always the best option for boost; in fact, it can actually make the car miserable to drive out of boost. lower compression = less power.
  11. E_SolSi
  12. rogelio93
    i was thinking of gettin 170 hp on allmotor then turbo the motor for even more power
  13. E_SolSi
    this is a stupid idea
    build for one or the other
    going one way then changing direction is a waste of time and money
  14. Matts96HB
