b18c aka Type R won let me go over 3500 rpm
Discussion in 'HYBRID -> EG-EK / DC' started by Thachboi, Jan 11, 2005.
  1. Thachboi
    Thachboi Junior Member
    I bought the 1992 civic cx hatch with a b16a2 n now i just swaped it 3-4 days ago to a b18c aka Type R n it wont let me pass 3500 rpm anyone know Y
  2. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    wrong forum dude.
  3. breed
    breed Senior Member
    New York
    could be a bad ecu.
  4. Thachboi
    its not the ecu. i tryed a h22,gsr,p28,mugen it dont work it boggs lik crazy n wont let me pass 3500
  5. BLKCIVICPN0I
    BLKCIVICPN0I Member
    LBC
    Check your distributor, cap, rotor, igniter, coil. I had the same problem and it turned out to be my cap and rotor. Also check your spark plugs and wires. Good luck.
  6. Thachboi
    i changed the sparks plugs to bosch +4 n changed the whole distributer n still it doese this.
  7. GSRCRXsi
    MD
    do you have a check engine light? you need to give a tad bit more info about the symptoms.
  8. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    my boy had the same problem with his b16 and i told him to change the dizzy because he had the wrong obd dizzy on that engine, he had an obd0 dizzy with an obd1 cvici and obd1 ecu! check the dizzy
  9. b16ahatch
    b16ahatch Senior Member
    def sounds llike its the dizz
  10. pissedoffsol
    and bosh plugs suck. throw those out before they do more harm than good.
  11. BLKCIVICPN0I
    BLKCIVICPN0I Member
    LBC
    NGK's rock!!! Got mine @ Pep Boys, cheaper there than Inlinefour here in So. Cal. Fuckers charge $60 bucks for a set of 4 NGK IX Iridiums!!! Pep boys sell em for $5-$6 each!! WAYYYY cheaper. :worthy:
  12. pissedoffsol
