b18c built
Discussion in 'HYBRID -> EG-EK / DC' started by 92eg27, Aug 26, 2014.
  1. 92eg27
    92eg27 New Member
    ct
    Ok right now I basically have a stock type r b18c. I'm in the process of getting the block sleeved n bored to 2.0.. Now I want to go turbo when the block comes back, does anyone have ideas on this kinda built. Like what kid of piston or rods i should run ect .. I'm trying to aim for 600 or 700 hp hopefully
  2. reikoshea
    Dallas, TX
    You're going to trailer this everywhere, right?
  3. 92eg27
    92eg27 New Member
    ct
    What you mean when u say trailer?? Like put it on a trailer , if that meant that then yes
  4. Briansol
    700 hp is no joke of a build. $$$$$$$$$ in supporting parts. Asking what kind of pistons and rods to use tells me you haven't done this before and don't really know what you're getting yourself in to.
    So, lets start with the basics.... what fuel are you going to run?
  5. 92eg27
    92eg27 New Member
    ct
    Gas 120 octane, n i see its no joke man. I've been doing research it's going to cost me, but the bulid going to be a over the winter build. So I'll have time to put some money together. N I'll be satisfied around 500 to 550hp honestly...
  6. 92eg27
    92eg27 New Member
    ct
    N u right first time doing this.
  7. get_nick
    Washington State
    I'm always entertained by big power builds, but nobody EVER finishes them. Is this going to be a track only car? I mean a legit drag monster?
  8. 92eg27
    92eg27 New Member
    ct
    Honestly I really wanna b able to hit the streets with it, like once in a blue, u know to catch a stunt to
  9. get_nick
    Washington State
  10. 92eg27
    92eg27 New Member
    ct
    See I knew that that's why I went from wanting 700 to 500hp smh... but hey that's things we have to deal with if we want to go fast lol... but thanks I really appreciate it ..
  11. get_nick
    Washington State
    wiseco pistons and eagle rods are pretty popular combinations as well.
  12. 92eg27
    92eg27 New Member
    ct
    One of my buddies told me to run 10:1 pistons that the sound right if I'm planning to run turbo?
  13. get_nick
    Washington State
    no, you want to go lower. think 9.0:1
  14. 92eg27
    92eg27 New Member
    ct
  15. Briansol
    Well, if you want to make serious power, you're going to want more than 9:1
    9:1 is safer/easier to tune but you'e going to have a much harder time making serious power with that lower compression.
    reikoshea likes this.
  16. 92eg27
    92eg27 New Member
    ct
    how bout 10:1 what's your opinion on that??
  17. Briansol
    Keep in mind, a piston is merely part of the compression calculation. the numbers on them represent 'stock' other things, which you simply won't be capable of running at these desired power levels.
    bore, stroke, head gasket thickness, head design/combustion chamber CC, piston design (dome or dish), deck clearance all contribute to total compression.
    If you go 9:1 piston, and then throw a thick headgasket on, you're in the 8's. mill the head, you're in the high 9s. etc etc
