B18c Gsr Engine In Civic Ex 1995
Discussion in 'HYBRID -> EG-EK / DC' started by hondacivicnos, Mar 13, 2003.
  1. hondacivicnos
    hondacivicnos Senior Member
    OK I just what to know what should I buy if I will want to swap b18c GSR engine in Honda Civic EX 1995?
    I did go to the SWAP section and I found all information about but I did not find anything about were can I buy it. So can you please tell me were can I buy every part that I need to swap b18c GSR engine in the Civic.
    1.ECU: P30(B16A), P61(B17), P72(B18C), P75(B18B)
    2. B-series throttle cable specific to motor, B17A and B16A throttle cables will both work, -B18C throttle cables are different due to the GSR intake manifold
    3. B-series engine mounts (more on this below)
    4. Integra Shift linkage/ 99-00 Civic Si Shift Linkage (del Sol shift linkage is about an inch too long, needs to be cut and rewelded to be made to fit, NOT RECOMMENDED!!)
    5. VTEC wires (This will include wires, and possibly plugs if your motor is lacking an engine harness)
    6. B-series Axles
    All I need is the place were I can buy it and its going to be better if it will be online...
    Thank you...
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Hmotorsonline
    Hybrid Revolution
    Password JDM
    You don't need aharness with vtec,cuz you have vtec.The only things your going to have to wire is the IAB and the knock.But definitely get a 94-95.
