I am in the market to purchase a new hybrid, I preferably would like to buy a CRX (1988-1991) with a B16 or B18 swap in it but I don't know much about the B18. I am going to go look at a 91 CRX with a "B18 DOHC VTEC engine" in it (as the seller has on his add). I know there are several different B18C engines but what if the seller doesn't know what kind it is (probably unlikely) or tries to pass it off as something like a B18C5, when its actually a C1 I'd want to know how to identify the engine. I previously owned a B16a CRX and I never really knew where the engine came from, It was OBD0, the engine was stamped "B16A" on the tranny/engine connection area and the plenum on the intake manifold was blank, it didn't say MPFI or anything. I think I've seen pictures of a B18C5 engine and it was easily visible that the engine had B18C5 stamped on it, in the same location has my engine had B16A stamped.
So in short, what should I be looking at when I inspect a 91 CRX with a B18C(?) swap? OBD, tranny, mounts? etc...
Thanks,
Scott
Thanks,
Scott
