Okay, here is the latest: I drained the radiator and flushed the coolant system so I could remove the hoses to have more access to the broken bolt (radiator hasn't been flushed since i put the motor in so it was well past overdue). Side note real quick: I highly advise routine maintenance after all this shit I've gone through on this car. Maybe if I had been a little better at maintaining everything, I wouldn't have all the problems that I do. Thats right, I am admitting that I have been a fool. Back to the story: with the hoses removed, I was able to get vice grips on the bolt and lock them, but was still unable to turn the damn thing. So I tried the dremmel trick on it (cut it so I could get a flat screwdriver on it and back it out), well...that didn't work either. So I had to drill the bolt out, which i did. I drilled a single hole in it and increased the drill bit size 2 more times. Each time shaving away a little more broken bolt. I used a punch and a hammer to try and get the rest of the bolt out of the way, but broke the distributor housing. It broke right where the bolt screws into the housing so now I can only attach 2 of the 3 bolts to the dist cap.
I put the new rotor on, followed by the new cap and wouldn't you know it, Napa sold me the wrong dist cap. The one they gave me was only about half the diameter of the cap bolt off, but it was too narrow. I took it back and they asked if the engine was a DOHC or if it has VTEC. I said both....cuz it does. Anyone else had this question asked of their motors? Any who, they didn't have the other one so I went to pep boys and they had it. I took it home, installed the new cap (using only 2 of the 3 new bolts), drove the car for about 15 minutes and it didn't misfire once. Usually, it acts really bad within the first minute of driving it down the road. That being said, I am cautiously optimistic that I fixed the issue. I will have a better idea when I get a day off work and the weather cooperates. Where is the ELD at and what does it do? I have said it before and will say it again, I don't know a whole lot about diagnosing driveability problems, but I am trying to learn. I am pretty much on my own when it comes to fixing my car, so I REALLY appreciate any and all help I get from you guys. Thanks again, Matt
