Need helps......don't know what wire to add or to take off......have both harness.....94 GSR motor into 97 hatch DX......have jumper harness for OB2 to OBD1 ECU.........motor already out.......now for the fun part.....wiring.....thank you and have a nice day!!!!
use your civic motor harness. try to plug in all the sensors that you can. you might have to lengthen a couple of sensors. the ones that don't plug in, swap the plugs from the gsr harness onto the civic harness. make sure you solder them!!! it helps to have a helms manual for both the car and the motor.
