b18c into 98 civic EX
Discussion in 'HYBRID -> EG-EK / DC' started by RotaryPWR, Nov 5, 2010.
  1. RotaryPWR
    RotaryPWR New Member
    JDM b18c (obd2a) going into a 98 civic ex (obd2a) using the JDM p72 ecu.
    Just a couple questions.
    Is there a cruise control vacuum port somewhere on the intake manifold? If so, where is it?
    There was a loose tube hanging from the hook-shaped port on top of the intake manifold. I took it out and hooked my brake booster vacuum line to it. Is this correct?
    Thanks in advance!!
  2. intenseneal
    intenseneal New Member
    Your motor might not have cc. You can just t into a similar place that the line was at on the D16 motor. Looks like #12 will be a good spot. #13 is your the intake valves, you will need to add the wiring from the GSR harness to the EX harness for this to work. There are a few plug that need to be changed also. An OBD2a GSR motor into a Vtec OBD2a Civic shoul be a 99% plug and play swap.
